Sp1 PnP Audio Device - 0 sound
Click the link in my last post,
Then Click the link in the picture below.
attachment.php
But is this for Vista 32? It says XP? Can't you just link the PnP driver? Like you did to the other quy? Thx anyway.
Once you get to the download page you can select your operating system from the top right in a drop-down box, I would link you but I cant find your motherboard listed on the downloads page, are you sure you have given me the right model?
Is this to any help? Asus M2N-Plus Vista Edition nForce 500 SLI MCP 4DDR2-DIMM 2PCI 4PCIe SATA Raid Audio GB-LAN Firewire Socket AM2 ATXASM2N-PLSLIV
AMD Athlon64 X2 Dual-Core 4600+ 2.4GHz 2x512Kb Boxed (with cpu-cooler!) Socket AM2ADA4600CUBOX
I copied it from the receipt we got when we ordered the computer.
the help was provided - go to that page that dmex showed and enter your operating system and such and download the drivers.
SP1 has been known to break drivers that were not 100% compatible with it, and the fix is to simply re-install the drivers to make the device work again.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
