SoundMax problems
mowh
hi ... i just have installed Vista x64. I had vista x32 before but now i've got Problems with my SoundMax-Software. The Driver from the Asus homepage work very well but not the SoundMax-Software. I cannot install it right ... in the Systemcontrol there is no entry and the Trayicon is not where it should be. Its not hided or something else ... i just cannot use it. The 32bit version of the Soundmax works but it is 32bit.
So my question ... is it neccessary to have the SoundMax as x64 or is there no dfference?
greetz
    Selfmade ;-)
    AMD Athlon 64 X2 6000+
    Nvidia Geforce 9800 GTX+
    OnBoard
    Samsung
greetz
Hi mowh,
Welcome to the forum, If the 32bit software works for you then I see no reason to change it.
To answer your question, no, there is no noticeable difference :)
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
Vista 64 bit is a bit faster one .... on doubt about that....But unfortunately ....... you will run into alot of problems to find softwares that work with it.
I really DON'T see the eason why you switched to 64...?
"If you still have alot of softwares that written for 32 bit...then switch it back.."
    S-Vaio FZ
    Intel Core2duo T7100-1.8GHz
    DDR2-2GB-PC2.5300-Sp.667MHz
    Mobile Intel Graphics Media Accelerator X3100-358MBvideo ram
    200GB/7200Rpm/Serial ATA
