sony vgn-ns240ew with vista ultimate 64 bit?
justwindows
dear all,
i just bought this laptop .
its features are given below.
i mainly use music production software therefore i need 4 gb ram to operate without any performance issues. so i bought 2 gb rams and vista 64 bit.
i installed the 64 bit.
but now i'm facing driver issues. especially in graphics adapter and network/wifi adapters.
can anyone please guide me through a source where i can find these devices' 64 bit drivers? i searched the web but i couldn't find.
do you think that it's impossible to run 64 bit in this system?
thanks in advance
alper
Specifications​
General​
Computer Type:​
Notebook
Type of Use:​
Portable
Action Buttons:​
AV Mode, Mute
Pointing Device:​
Electro-static touch pad
Hardware​
Keyboard:​
QWERTY, 86 keys with 2.5mm stroke and 19.05mm pitch
Camera:​
Built-in 1.3 megapixel MOTION EYE® camera and microphone
Processor​
Type:​
Intel® Core™ 2 Duo Processor T6400
Speed:​
2.0GHz
Front Side Bus Speed:​
800MHz
L2 Cache:​
2MB
Technology:​
Intel® Centrino® processor technology
Memory​
Type:​
DDR2
Installed:​
3GB PC2-6400 (2GBx1+1GBx1)
Maximum:​
Speed:​
800MHz
Hard Drive​
Capacity:​
250GB
Speed:​
5400rpm
Interface:​
Serial ATA
Optical Drive #1​
CD Support:​
Read / Write (CD/-R/-RW)
DVD Support:​
Read / Write (DVD±R/±RW/±R DL/-RAM)
Expansion Slots​
Multimedia Card Reader:​
One Memory Stick PRO™ (Standard/Duo)
media slot with MagicGate® functionality
One ExpressCard® / 34 media slot
One Secure Digital (SD memory card) media slot
Audio​
Sound System:​
Intel® High Definition Audio
Display​
Screen Size:​
15.4"
Resolution:​
1280 x 800 (WXGA)
XBRITE-ECO™ Technology:​
Yes
Graphics​
Processor:​
ATI Mobility Radeon™ HD 3430 with Total Available Graphics
Memory of 2040MB (max.)
Chipset:​
Intel® GM45 Express Chipset
Inputs and Outputs​
Modem Jack:​
1
Microphone Input:​
1
USB Port(s):​
4 (2.0 compliant)
VGA Output(s):​
1
DC-In:​
1
i.LINK® Connection:​
1 (4pin) i.LINK® connector (IEEE 1394)
Ethernet Connection (s):​
1
Networking/Modem​
Ethernet Protocol:​
10Base-T/100Base-TX/1000Base-T (Gigabit)
Ethernet Speed:​
Fast Ethernet (RJ-45)
Modem Type:​
Integrated V.92/V.90 Modem (RJ-11)
Wireless LAN:​
Intel® WiFi Link 5100AGN (802.11a/b/g/n)
dear all,
thanks in advance
alper
Hi alper, Welcome to the Forum.
I do not think you will have a lot of luck with Sony. My advice would be to use a program like this; SIW | System Information for Windows by Gabriel Topala It will help you to identify the components that you need, ie. Manufacturer and Model. As most of these devices are fairly common all you need to do then is visit said Manufacturers site and search for x64 drivers.
I hope this helps
Pooch
    Self build
    Asus M3A32-MVP Deluxe
    8 gig Samsung PC800 RAM
    NVidia 9600gt
    AD1988b
    1680 : 1050 1280 : 1024
    Enermax Chakra
    Easy Line Laser Mouse
    Standard
