Someone explain "ghosting" and recovery to me?
nate42nd
Learing every day
I just walked into my home office and there had been a power outage. I got the message (on my 4 month old Vista x64 system) "disc boot failure please insert system disc and press enter" I am scared to death. It finally booted up but I need to get to work fast. I can find a lot of tutorials to create an image but what if I need to use it?
I have Macrium reflect "free edition" I need to create an image. I can figure that part out. My questions are....
1-Can I create this image on another computer on my home network? If so, how would I use this image if I need it.
2-Does creating a ghost image create a bootable .iso and how do I use the ghost image.
3-If my HD fails. I need to get a new one, restore Vista from the recovery disc(s) I already made with HP recovery disc maker to factory state. Then use this "ghost" image to get (what) back? Software? Settings? That's my main worry.
Thanks to anyone who will explain this.
    The Terminator
    Core 2 Quad
    Gigabyte EP45-UD3P
    4X2GB GSkill 1066Mhz
    GeForce 9500 GT
    Realtek
    Samsung SyncMaster 932 bw 19" and Syncmaster 2033 20"
    1440 X 900 and 1600 X 900
    Patriot Torqx 128GB SSD WD Black 640GB
    Corsair 750HX
    Lian Li PC-B70
    Arctic Cooling Freezer Pro 7
    Microsoft wireless laser mouse 5000
    An old e-machines PS-2 (I have HUGE fingers and it works)
    7 Mps
Macrium Reflect will not backup a Network machine...at least not the Free version.
Other Paid apps such as Acronis True Image and Ghost have this feature.
When you create an image the entire system including OS,programs and Data are copied completely. The image can not be created on the same drive/partition that is being imaged...in other words you will need another drive or partition for the image file to be created to.
Once it is created it's often a good idea to burn it to CD/DVD for safekeeping.
To restore the image you use a bootable floppy or CD that you create directly from the image app...Macrium asks you if you want to do this at startup. The boot CD does not include your backup image ...it just launches the app to restore.
You then point it to where you want the image restored to (destination) and where the image resides (source).
The advantage is it takes me about 15 minutes to restore my drive back to where it was when the image was created...much faster than re-installing Windows;, tweaking everything and re-installing all your apps.
Hope this helps.
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
It looks like Macrium does let you use network computers. It is creating an image right now on a different computer on my home network. That's great.... So this is an option to re-installing windows? And it will put the exact image (including settings and software) back onto a new hard drive? This is great. I hope it works.
Just to get this strait....if my hard drive is going out, I can buy a new one, I don't even have to install Windows....just put this image on the new drive with the help of the linux or bart cd Macrium helps you create right?
    The Terminator
    Core 2 Quad
    Gigabyte EP45-UD3P
    GeForce 9500 GT
    Realtek
    Corsair 750HX
    Lian Li PC-B70
    7 Mps
Should do :)
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Thanks for the reply. I created an image on a PC in my home network. The image is of Vista x64. That still should work okay right. It's on an XP machine. Also, in case anyone wonders, the image is 19GB. I left the compression at default. This seems to be a great program. (Macrium)
    The Terminator
    Core 2 Quad
    Gigabyte EP45-UD3P
    GeForce 9500 GT
    Realtek
    Corsair 750HX
    Lian Li PC-B70
    7 Mps
