Some Weird Desktop Shortcut Icon Issues
Ex_Brit
If you're going through hell, keep going
Since installing IE8 RTM in Vista SP1 x86 I've been having some problems with internet shortcut icons not displaying correctly on my desktop.
I've tried deleting and redoing them, tried using AM Deadlink to refresh my Favourites icons to no avail. They show normally in Favourites but show as a smaller version within a white frame on the desktop. This doesn't seem to effect all of them, just some.
I've attached two thumbnails to illustrate what I mean. The first one is the Canada Post item in Favourites and the second one is the same shortcut on the desktop. As you can see there there's another one doing the same thing for Newegg.ca.
I think I am right in saying that it's not a case of rebuilding the system icon cache as that only effects system icons, am I right?
FYI desktop resolution is 1680 x 1050 and I have the desktop icon size set to Classic.
So any ideas folks?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Maybe it shows the favicon in the shortcut instead of the IE symbol.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
That's what it's supposed to show. My question is why is the favicon so tiny inside the white border?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
I hope someone has some ideas...some have now have degenerated into blank white icons.
This all started right after installing IE8 RTM.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Just a thought, I'm using IE8 but with Vista SP2 x86.
Could it be IE8 doesn't like SP1.
    INTEL QUAD 6600
    Gigabyte EP35-DS4
    4 gb
    GeForce 8800gt
    24" ACER
    1440 X 900
    500 GB 320GB
    700WATT
    ARCTIC
    Av.MTH, Download 8.27, Upoad 0.91
I doubt that but it's a thought, thanks. I've managed to restore some. I've repeatedly cleared my cache, temp files etc. but I should really need to do that as I've got loads of resources.
The rest just refuse to change from the blank "white piece of paper with a fold on one corner" type image. despite the correct icons showing in Favorites.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
I think I've tried most of those already Shawn but thanks anyway. I just cleared out everything again and started over...same thing. The favicons either show as white or white with a mini-version of the actual favicon in the middle. But only for some sites - weird. I'm not too happy with IE8 to be honest - I find it slow and even in compatability mode many websites that are behind the times don't work properly.
Shame really because, as much as I like Firefox, I prefer the look of IE.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Well I gave up wondering why some sites worked OK and others, including this one and Win7 Forums didn't and changed the icons. Fortunately I found the identical icons elsewhere.
Now I'm happy but not enthralled by IE8 RTM needless to say. The trouble is, I prefer IE simply because of the ease of creating shortcuts. To do the same in Firefox is like major heart surgery.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Still no solution here, sorry.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
