Hello,
I recently uninstalled hp solution center 13.0 because it wasn't working right. The message saying my "scanner is unavailable" to fax please try again is annoying. My laptop is networked and everything else works fine. The scanner works fine in any other request. Any help with this?
On another note... if you've recently wanted to uninstall and reinstall solution center and are finding it hard to find the software online to reinstall, you'll most likely need to use the printer cd. (If you still have it of course). Then you can go to the hp website and download the update to 13.0 and hope it works better. Hope this helps...
