Solitaire save issues
Rage
Hi, my parents got a laptop with vista home 32, and they enjoy playing Solitaire on it, but they have a problem, if they stop half way in a game and close it they get spamed by the "DO YOU WANT TO SAVE!!!11oneeleven" message.
Im sure whoever designed it figured it would be awesome but its pritty anoying and it dosnt remember that you said no, normal software have a dont ask again option but not this.
In the options I can set it to always save and always load on start, yet if I disable these 2 options ill be prompt every time its closed and opened (if a savegame have been made).
So my question is how do i disable the prompt for saving and loading? And I know i can remove the load prompt by removing the savegame but its not a permanent solution.
---sorry---it seems that there is NO cure for this issue---I just clicked the game a dozen times too, and it does the same idiotic-repeat-sequence---(it is a built-in-Windows program and I personally could not find a way to tamper with it either!)---also, checking online, this seems to be a major-issue with zillions of other solitaire-fans---
---my suggestions: buy your OWN solitaire game, they can be under $10, or borrow from someone-download it, or what I do is cruise the websites for FREE-online games too---
peace
    eMachines D620 (laptop)
    AMD Athlon Processor 2650e 1.60GHz
    ACPI x86-based PC
    (RAM) 1.00GB
    Internal DAC (400MHz) - memory: 382 MB
    Realtek High Def Audio
    ATI Radeon X1250 - 14"
    1280 x 800 (60Hz)
    ST9160310AS ATA Device
    Stealth~graphite
    Synaptics PS/2 Port Touchpad + Microsoft Optical Mouse 500
    Launch Manager Version 2.0.02
    Cable/wireless-router
    NO WEBCAM - (privacy)
