Slow Startup Problem
danbee80
hey folks,
my startups have recently slowed down. I have disabled stuff from the startup selection, and still had no luck.
I think the problem lies with the network connection. It seems to be taking a while before it connects to my router. not sure why this started happening usually used to be alot quicker.
Any Idea ??
Wireless? Wired? Are you running auto? What speed and duplex? Did you update the NIC drivers?
    16GB DDR667
    SAS RAID
hi mate,
its wireless, and i believe it is auto yes. And i did not update anything. It was ok a couple weeks ago, its started being slow only recently.
my router is a linksys n ultra range plus and the usb base on the pc is a linksys N also.
Pc is a intel quad with 2 gig ram.
Is it secured? Or you are being slowed down by hot spot users?
    HP Pavilion dv7-1170us
    Intel Core 2 Duo T5800 @ 2.00GHz
    Compal
    NVIDIA GeForce 9600M GT
    1440 x 900
    289.09 GB
    Synaptics PS/2 Port TouchPad
    IBM enhanced (101-or 102) keyboard
    cable Wireless
do you have wireless assistance? If so, make sure it starts at start up.
    Compal
    1440 x 900
    289.09 GB
    cable Wireless
You will find it on start search by typing wir or go misconfig and start up and see if it is there and checked.
Better yet, learn some tricks on how to optimize vista performance:
>Start > Help and support > Performance and Maintenance. Here you have suggestions on disk cleaning, defrag (when was the last time you defragged?), trimming start up programs, freeing spaces, etc. It's lots of fun.
It's addicting. Make sure you do not OD
    Compal
    1440 x 900
    289.09 GB
    cable Wireless
You could go to Control Panel - System and Maintainance - Performance Information and Tools and then click on Advanced Tools in the left column. Certain start up performance issues may list at the top of the screen you get.
    Dell XPS720
    Intel Quad Q6600 2.40GHz
    4GB DDR2 800MHz
    Creative SB X-Fi Xtreme Gamer
    Dell 2407WFP-HC
    1920x1200
