SLI Memory / Timing Issues
Kinematic9
Hi All,
Just a question - I have 4 1gb sticks of Corsair 6400/800mhz ram (ddr2) It states on the ram that they are SLI ready along with the timing and voltage (4-4-4-12 2.1v)
Bios defaults to 5-5-5-18, and SLI off.
Did a fresh install of windows vista home prem x64 yesterday, removed 2gb of ram for the install - I was able to enable SLI memory, which then moved the timings to the optimized settings. All went well, booted into the system great, updated to SP1 - shut down the machine and added the other 2gb.
Now in the BIOS, SLI memory settings are X'd out, I am unable to turn this on. The sticks are identical, but now it is telling me its unable to find SLI compatible sticks - defaulting everything back to 5-5-5-18. Manually changing the timings to 4-4-4-12 results in startup errors and a reset of the BIOS.
That being said, a) would that make a huge difference and b) anyone know why this may be happening?
Thanks ahead of time
    Intel Core 2 Duo E6850 3.0GHz
    EVGA nForce 680i SLI 122-CK-NF68
    4x1 GB Corsair PC2-6400
    EVGA nVidia GeForce GTX 280 SSC
    Onboard Realtek R2.10
    24" & 22" Gateway LCD
    1900x1200, 1680x1050
    WD Velociraptor 10k 300 GB SATA II Maxtor 500 GB SATA II WD 400 GB SATA II
    Antec 650W Modular
    Antec Nine Hundred
    Zalaman
    Razer Habu
    Razor Reclusa
    12Mbs
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Hi All,
hmm i had this problem, my system defaulted to 8-8-8-24, and my ram was stated in my system specs on the bottom left, this happens because you have switched your ram to dual channel mode, you need to go into the ram settings in the bios and switch the ram to unlinked mode, this will allow you to change the settings to SLI mode and change other settings to how you want them, i will post pics in a minute with where to go and how to do.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
    Antec 650W Modular
    Antec Nine Hundred
    Zalaman
    Razer Habu
    Razor Reclusa
    12Mbs
Thanks for the reply,
I just attempted to change this setting from AUTO to Unlinked, but next to SLI READY MEMORY (First option up top), there is still an X to the left of it, and I am unable to select this.
In the startup, it says SLI MEMORY DETECTED, 4 DIMMS NOT SUPPORTED
As well, CPU-Z is showing DRAM Frequency at 400mhz, im not sure if thats because its 400 each channel?
    Antec 650W Modular
    Antec Nine Hundred
    Zalaman
    Razer Habu
    Razor Reclusa
    12Mbs
Still no success with this =( If anyone else has any suggestions, please let me know. Thanks!
    Antec 650W Modular
    Antec Nine Hundred
    Zalaman
    Razer Habu
    Razor Reclusa
    12Mbs
