SLI flickers and tears quick fix!!!!
DaKine73
OK! So the lattests nVidia drivres are driving us mad, with this flickers and tears when playing 3D games in SLI with bridge.
Da' Fix!!!!
Go to nVidia .com get this beta driver (186.08_desktop_win7_winvista_64bit_english_beta) or your flavor of choice wether is x32 or x64, I like x64 my pc seems to like it!!!
This is a Beta driver wich includes nVidias lattest new toy "Stereoscopic 3D"
Down load it and do your thing.
Da' Settings!!!
Get a pair of 3D cheap paper glasses. red and blue lenses.
go to set up your stereoscopic 3D thing.
Once that is set and you are wowed and drooling with the 3D effects.
Do this in the Stereoscopic tab
1....Check the box ....Enable Stereoscopic 3D ON!!!!!!
2....Check the box ....Hide stereoscopic 3D when game starts ON!!!!
And you are done! SLI working
And use keboard short cut to flip from normal mode or stereoscopic mode while playing your fav game.
ex. ctrl+t turn stereoscopic on or of. you' get the hang of it. I did!!!
Note!!! this worked for me!!!
this is what i found and im posting it to help you out! Dont blame me if it dont work for you Blame your recruiter not your drill sargent!!!!!
Performance with this driver still a little questionable. but at least SLI works, isnt that what you paid for!!!!!
    Alien Tech
    AMD Phenom 9850 Black Edition
    MSI K9N2 Platinum
    OCZ PC6400 SLI Edition 8GB
    XFX Force 8600GT x2 (sli configuration)
    On board Realtek HD 7.1/ SRS Audio Sandbox 1.7 x64
    Acer H213H
    1920x1080p 32bits
    SCSI\Disk____NVIDIA__STRIPE____74.53G Sea Gate SCSI\Disk____NVIDIA__STRIPE___298.09G Hitachi SCSI\Disk____NVIDIA__STRIPE___372.61G Hitachi
    Power Up 550watts
    Alien Tech (new system in an old chassys)
    By Air 7 fans
    Logitech HID-compliant LX3 Optical Mouse
    Microsoft USB Digital Media Pro Keyboard (IntelliType Pro)
    1mb
    This Rig is OC'd by 13% stock CPU is 2.5GHZ to 2.8GHz FSB (HT)225MHZ RAM is also OC'd Stock 800MHZ to 900MHZ Ultra Media Dash SD/USB/eSATA/Audio/1394/CM/SM/CF-MD/MS
??? i am confused ??? arent graphics cards suppose to tear from no vsync and flicker from a lower refresh rate? XD and 3D Vision is too pricey and performance taxing...
    JUST ME/Custom Built
    Intel(R) Core(TM) 2 Quad Q9550 E0 2.83 Ghz @ 4037.5 Ghz
    EVGA NFORCE 790I SLI FTW Digital PWM
    8 Gig Corsair XMS3 DHX 1600 Mhz DDR3 CAS 9
    2x GTX 480's w/ Koolance VID-NX480's
    Creative SoundBlaster X-Fi Titanium (non-Fatal1ty) Edition
    Acer P243W 24" Premium Series
    1920 x 1200
    Seagate Barracuda 7200.11 1 TB HDD 32mb cache (3 Platters, 6 Heads model)
    Ultra X4 1050W PSU 76A Rated 12V SLI
    Antec 1200 Full tower ATX case
    x2 Thermaltake Blue LED 120mm 2800rpm fans, Zalman CNPS 9900
    Logitech LX310 2.4Ghz Wireless Laser Mouse
    Logitech LX310 2.4 Ghz Wireless Keyboard
    32mb Download, 12mb Upload from Comcast
    300$ custom watercooling setup. Antec 1200 big boy Radiator, Dual bay XPSC reservoir with clear bubble window, OCZ hydropulse 800L/H 12v pump, 12 ft tygon 1/2" ID, 3/4" OD tubing, Feser One UV Green 1 L fluid. (and VID-NX480 waterblock)
you are correct!
but in this case vsync nor refresh rate are the problems.
this problem is related for the lattests drivers 182 to 185.
for video cards series 8500 8600 8800 ect. using sli with bridge (not sli via pci)
for some reason other than the refresh rate, vsync,ect. when playing 3d games that use the full beneffits of sli the bridge this flickers and color tears will occur.
now if we remove the bridge and use sli via the pci bus the problem is corrected but the performance goes down.
since i paid to have the full sli brige performance, i will continue to use it.
and at least i see that our friends at nVidia are working on this fix. (is their fault anyways)
and doing the settings that i mentioned on my prior post fixes this anoying problem,
alowing you to use full sli and to use 3d vission as well.
and yes nvidia 3d vision is expensive but with the beta driver 186 they introduced the 3d vision settings for both the $500 gadget and for the $0.40 3d paper glasses
so if you are broke like me, i recoment the cheap glasses. the effects still stunning.
    Alien Tech
    MSI K9N2 Platinum
    Acer H213H
    1920x1080p 32bits
    Power Up 550watts
    By Air 7 fans
    1mb
Here it is the new whql certified driver for windows vista x64 186.18_desktop_win7_winvista_64bit_english_whql
Same thing do as explained above all should work fine
    Alien Tech
    MSI K9N2 Platinum
    Acer H213H
    1920x1080p 32bits
    Power Up 550watts
    By Air 7 fans
    1mb
