Since changing ISP and router having major problems browsing
ashido
Hi there
Since moving ISP's earlier in week and recieving a new router I am having huge problems on my vista system :(
I know this is down to vista as I can boot onto a XP partition and it works fine,,all other laptop and xbox run perfectly well aswell.
I cant get to certain pages,,,the routers own page for 1 on local network, facebook hangs for ever, luckily i can get onto some, like this page tho lol :)
I have tried all the TCP/IP resets that I have seen on this forum and others but same old problem, either wont load some pages or partially loads and hangs. I also stream music and tonight I had buffering probs trying to do on vista, switched to XP partition and not a problem.
Any help appreciated
Thx
Neil
    AMD Phenom 955 be
    Gigabyte GA 870 USB3L
    2x4 giig Corsair XMS3
    Geforce GTX250
    External
    2xAOC 23 inch
It might be that some add-on is causing a problem. You can try disabling add-ons one at a time to see if the behavior stops.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
