Signature 01 auto failover
Mikeymike48
Hello,
I'm new to the forum. However, I really need help on my Vista OS on an HP desktop PC. I am getting the following reports:
1. "Startup repair cannot repair this computer automatically".
2. "Problem signature - 01 Auto Failover"
I have read some of the responses to this problem and have 2 problems. First, I am a novice when it come to this sort of thing, and next, my PC did NOT come with a disc.
Question: Obviously, Vista is Trash ie, most of the responses, and so is 7. However, since 7 seems to be the only option to upgrade to, how do I do that after purchasing a 7 upgrade disk, if I can even do it???
By the way, a common problem I find in your threads is the downloading of photos, which is the last thing I did before my PC crashed.
Also, will I lose "My Documents" if I can an upgrade???
If ANYONE would be so kind as to offer me some advice (in NOVICE Terms Please :huh:, I would greatly appreciate it.
Mikey
Welcome
See if you can boot from a boot DVD?
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
you create a recovery DVD, you may be able to boot to recovery options
Create Recovery DVD
The Vista recovery disk is used to boot Vista when it won't boot - to run Startup Repair, System Restore, access a Command Line, Recover using a Vista Backup Image, etc.
System Recovery Options
If Vista will not start now, boot the Recovery CD to run Startup Repair which automates System Restore as well as numerous other tests including System File Checker which can repair system files which are not corrupted beyond repair.
If Vista still will not start, try booting into Safe Mode to run sfc /scannow to repair System files.
Special Thanks Given to Seven Forums.
Below is a bulletin distributed by MS to explain the start up procedure when Windows will not boot.
  • Startup Repair. Startup Repair is a Windows recovery tool that can fix certain problems, such as missing or damaged system files, that might prevent Windows from starting. Startup Repair is located on the System Recovery Options menu, which is on the Windows Vista installation disc. If your computer has preinstalled recovery options, it might also be stored on your computer's hard disk. For more information, see Startup Repair: frequently asked questions and What are the system recovery options in Windows Vista? If your computer does not include Startup Repair, your computer manufacturer might have customized or replaced the tool. Check the information that came with your computer or go to the manufacturer's website.
  • Change restart settings in safe mode. If your computer is stuck in a loop where Windows fails, attempts to restart, and then fails again repeatedly, restart your computer in safe mode and select the Disable automatic restart on system failure checkbox. For more information, see Advanced startup options (including safe mode).
  • Reinstall. If no other options have solved the problem, and you are sure that your computer's hardware is functioning normally, you might need to reinstall Windows. A custom (clean) installation of Windows will permanently delete all of the files on your computer and reinstall Windows, so only use this option if all other recovery options have been unsuccessful. After the installation, you will need to reinstall your programs and restore your files from backup copies. For more information, see Installing and reinstalling Windows**.
Dont fret, if you give up you can backup your documents
Use Ubuntu Live CD to Backup Files from Your Dead Windows Computer - How-To Geek
and then reinstall
You will get your documents
You can also do an upgrade install
or repair install with the DVD.
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
Try to boot in safe mode and then do a system restore
If you try all and still have problems, you can back up your documents with ubuntu.
