SFC /scannow issue?
darkstrike
Hi all,
New here, but I have an account on the Win7 forums. I've got an Acer laptop I'm having issues with and it's running Vista Home Prem. 32-bit.
Last night, I uninstalled 3 pieces of software from the control panel for a friend who got sucked into a $600 for two-year contract with some remote-help company in California called Omnitech.
All I did, as I said, was uninstall their software from the Control Panel for her. Upon restart, I received a BSOD and it BSODs no matter what I do now. The machine won't boot normally into windows, it won't boot into Safe Mode (same BSOD...won't boot into ANY safe mode, with Networking, Command Line-only, or otherwise).
I have booted into the machine's recovery partition from the factory and used the Repair Computer option to get a command line. I've run a ChkDsk and want to run an sfc /scannow, but when I run the sfc /scannow command on her C: drive, all I get is an error saying "Windows resource protection could not perform the requested operation."
I'm logged in as her account (which I am pretty sure is set as an Admin account) because I can't log into the normal Administrator account, she has no passwords on any account, but if I select the Admin account and hit enter with a blank password, I just get an error that that account is disabled.
Any ideas how to get the sfc command working....?
I would try this
http://www.vistax64.com/tutorials/67567-administrator-account.html?filter[11]=User Accounts
Also I would search for any indication this company put a hook in so that the software cannot be removed. If so, there may be a way to clean up the mess it leaves.. if that is in fact what caused it. Just speculating here.
Edit: a quick search shows complaints. A search through them may yield a workaround.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
What about a System Restore to before the Omnitech program was installed?
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
