surfshack66
ill start by posting what i have in other forums that have not worked out so well..
i think my msi 163a laptop will not recognize the hard drive...when i try to boot it says this
PXE e61 media test failure, check cable
boot failure
press any key to continue
if i boot from my vista disc to repair. it cannot find an operating system but it gives me the option to load drivers, which doesnt help because i dont know which drivers to load,
tried changing boot order around to enable just hard drive, but then i get bootmgr is missing
also when i turn on my computer it sits on the screen that says intel, press del key to run setup. press f11 tp run boot meny, press tab jey to show post sreen
i tried all of those and the only one that works is the last one...if i keep pressing delete it will bring up the bios
so this is where im stuck...any help would be great..also i tried reinstalling vista all together and it works up until i get an error during "installing updates"..the error says it cannot update the registry..or something similar to that...please help!
boot failure
