Setting UAC Control to allow certain Programs
xguntherc
I Click Home To Much
Basically I do not want to completely turn off the UAC because i like what it does. I think it is a great addition to vista and win 7.
I have eVGA Precision (GPU overclocking and monitoring software) set not to run at startup. but to start and up the default videocard fan speed. then it closes, its a setting in the program. So i have it set to turn up the fan speed at startup. but the program doesn't continue to run.
BUTTTT everytime i start the PC the annoying UAC pops up instantly wanting me to "allow" evga precision to run. So can I setit to ALWAYS allow it.. without disabling the UAC
Thanks!!! Help will be rewarded
    Q9650 E0 4.0 GHz @1.304v
    eVGA 750i FTW
    eVGA/MSI GTX 260 SLI
    X-Fi XtremeGamer
    Samsung T240 & 226BW
    1920x1200 & 1680x1050
    PC P&C 750w Silencer PSU
    Logitech MX-518
    Logitech G11
You can set the task scheduler to start your program at a given time or on a given date, or after certain other criteria have been met, since the task scheduler is elevated the UAC will not activate, if you want to start it from a shortcut, you can set it up in task scheduler, then create a shortcut to the the task like so
c:\Windows\system32\schtasks.exe /run /tn "[folder]\[taskname]"
more information on how to do this is available here Bypass UAC using a Desktop Shortcut
    Home Built
    AMD 6000+
    ASUS M3N78-VM
    Kingston 8GB
    NVIDIA 8800GT
    VIA
    CIBOX 22" Flatpanel & Panasonic Viera 42" Plasma
    Maxtor 250GB Samsung 250GB Samsung 320GB
    500W
    XCLIO
    Air / Fan
    Logitech MS Revolution
    Logitech G15
    10MB
Personal opinion only -
Anything Norton I tend to avoid - like the plague.:zip:
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
Works great for me too.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
