SETI@home UFO crap
Yes. I find it very satisfactory that my computer can find a cure for a illness, though I do hate what it does to my CPU.
    Gateway: GM5472
    AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ (2 CPUs), ~2.
    ATI Radeon HD 3650
    Dynex
    Dynex
what does it do to your CPU?
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
It just uses it all up. Theirs probably a way to change it but I never searched around for it. Note: BOINC has many services like rosseta@home and much more that have much more relestic goals.
    Gateway: GM5472
    ATI Radeon HD 3650
    Dynex
    Dynex
Thank you
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
Folding@home is a very worthwhile cause...
Folding@home - Main
Real results.
Be prepared though...running these apps generally push your hardware. A lot of data crunching.
But hey...its a good way to use those idle processes :P
    My build
    Core2Quad Q9550 yorkfield C1 3.8G
    GIGABYTE GA-EP45-UD3R
    8gig Kingston HyperX 8500 CL5
    Gigabyte GTX280 1G...generally stock.
    onboard
    Samsung 24" 2433bw + Benq 19" FP91G+
    2 x Samsung 500G Raid0 1 x Samsung 1TB 32
    Thermaltake Toughpower 850W
    Antec twelve hundred.
    Air...a lot of air. Thermalright 120 push/pull,8 case fans,
    Logitech G5
    Logitech G15
    ADSL2
Folding@home - Main
Real results.
I run this on my pc. I set it to only run when my computer is idle after 2 minutes. Good way to put a computer to use when i am not sitting at it.
    Intel Core 2 Duo 3.0Ghz (E8400)
    Asus P5N-T Deluxe
    OCZ Platinum 8GB
    BFG Geforce 9800GTX OCX\BFG Geforce 9800GTX OC [SLI]
    Integrated
    Samsung T220
    1600x1050
    Seagate 500GB
    Corsair 750W
    Antec 1200
    7 Fans, ASUS Triton 79 Edition (for cpu cooling)
    Razer Krait
    Logitec G15
    gateway/m6881
    3GB
    500GB WD
    logitech
    fios 35MB not!!!!
again,
how does it use up my CPU and what will happen if it's used up.
nothing will happen. Well if you are sitting at your pc doing work and using programs that use up a lot of cpu resources they may begin to respond slow or even stop responding. Otherwise, it won't damage your cpu at all. Its better to run it only when your computer is inactive...aka idle.
    Asus P5N-T Deluxe
    OCZ Platinum 8GB
    Integrated
    Samsung T220
    1600x1050
    Seagate 500GB
    Corsair 750W
    Antec 1200
    Razer Krait
    Logitec G15
