Seperate a audio
panais
Power User
I have one video and when play it i hear 2 languages the same time.
Is there any trick/software to remove the one?
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter KINGSTON HYPER X FAN +Cordless Rumblepad 2
P
what is the movies name and what app are you using to play it?
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Is an old very rare movie <<siver homnen>> in mkv format and when i play it i hear both english and japan tha same time.
Iv tried mkvmerge etc but....
Both sounds/languages are in the same audio file so is little tricky to seperate them.
(The languages are not in seperates audio files to right click and choose the one or the other via the player properties )
I need an advance program to edit the audio file if that is possible.
I use many players vlc tiger bsp zoom wmc... are all good for mkv/matroska format
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
What you need to strip one language is a ripping tool that handles MKV files. there is a comprehensive site (doom9.net i think) that has any audio or video tool you will ever need. if you google doom9 its there
Good Luck
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Good Luck
Ken
Cant find anything helpful
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
Good Luck
Ken
dont think this would be helpful? VobSub Language Editing Guide
Goto doo9.net guides audio ripping removing language streams. Might be helpful
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
What exactly i mean...
I have a movie in MKV format.
I use mkvmerge and i extract the audio from the movie in MKV format.
So now i have one MKV audio file.
When i play this MKV audio i hear 2 languages the same time.
What exactly i want...
I want a program to open/edit the MKV audio file and remove the one language!!
Then with mkvmerge i will add back again the <<new>> audio in my movie,so i will hear only one language when i watching it.
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
P
I understand. thats called ripping out a languge. You might also be able to do it if each language is in a seperate channel. If nothing on doom9 looks good to you have you tired googling it?
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Cant find the solution.
Is very important for me!!
    Custom Built by me.
    Gigabyte GA-X38-DS4
    ADSL 4000plus
