Security problem
Bobh
I'm not sure I have a problem but I need advise. I am running Vista Home Basic. I am using Avast antivirus. When I go to the security Central and I click on Malware protection I see the following: Spyware and other malware protection - Windows Defender and Avast antivirus both report they are turned on. Are these two in conflict with each other? If so how do I turn off Windows Defender? Thanks Bob
Hi Bobh,
Personally I run both the Windows Defender and my AV at the same time. I didn't find any conflicts between them so far. Perhaps, others will have different opinion about this.
If you really want to turn off Defender, in the Start Search box type System Configuration and run it as Administrator. In the System Configuration window click Services and scroll down to Windows Defender and unmark it, click Apply next OK. Reboot your computer.
Hope this helps. Cheers...
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
leave them both on different programs and will not interfere with each other, i am running both on my wife's laptop (Vista Home Premium X86) and my desktop (Vista Ultimate X64) and have no issues.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Confirming what Martee & fadedrs have said. Both progs should exist together in harmony. Certainly leave Defender on too. :)
    IntelCore 2DuoT8300@2.4GHz x2
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
