Security Problem
nebulaleo
Hello everyone
i'm use vista home basic. After i install SP1, many problem occur. I cannot copy file, cannot paste, cannot save file, cannot browse files. So, i restore my system. i think everything fine, but my system security does not working. I cannot Turn On the windows security, cannot use windows defender and cannot use windows update.
When i try to open windows defender, this message out ;
“ Application failed to initialize: 0x80070006. The handle is invalid.”
when i try turn on windows security;
“ The Security Center service can’t be started ”
when i click check for update, this message out ;
“ Error(s) found:
Code 80070424 Windows Update encauntered an unknown error. “
Can someone help me to resolve this problem?
Sorry, maybe my language not so good...
Sounds like you might have corruption (either user caused or malware caused). Try a restore to before the errors occured-if you have insufficient restore points you may to reinstall Vista, and if you are using a registry cleaner stop. They are nortotious for deleting critcal Windows components as they cannot discriminate between legitimate and unwanted items and this results in Windows/program file corruption.
Check for malware here:Free ESET Online Antivirus Scanner
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
