Solved search window help
ching1206
ok
i use msconfig very offen to close some apps n speed up my startup.
But everytime i type "msconfig" or other commands
the serach window opens.....
be4 the system configuration windows just opens
now there's a extra step to it...
how to i disable the search window option?
Thanks
Why don't you just create a shortcut for msconfig on your desktop?
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
You're welcome Ching. I'm happy to hear that you got it sorted. :)
