I am having a problem with my Ricoh SD/MMC Host Controller and the SD Host Adapter (that is natively installed by Vista) on my laptop. When my SD card works, I can see that both of the Host Controllers are available in the Device Manager, however the next day when I turn on my Computer, both options will dissapear in the Device Manager and my SD Card will not work.
I tried to forcefully install the Ricoh SD/MMC Host Controller again using the "Legacy Driver" option and it gave me a blue screen of death from which I couldn't even boot Windows to safe mode. I then went to "Last Known Good Configuration" and then the Ricoh SD/MMC Host Controller and the SD Host Adapter were back in the Device Manager.
The next day however, the same issue occured in which both Controllers dissapeared
Why is this happening? I have the latest drivers installed from ASUS (my laptop manufacturer).
PS:
Today in the morning it dissapeared once again, I happened to put my computer on stand-by for a few minutes, and then when I turned it back on, both controllers appeared again
. It only dissapears the next day (when I leave the computer off for a very long time), because if I try to restart the computer 10 times, it will stay there.
PS:
