SD Card 2gb not working...
fouroh77
I'm not sure if this is a problem with a driver, my card or something else. I have a PYN Optima SD card, 2GB and when i put it in the SD/MMC card slot on my laptop (Dell 1525 with Vista basic) it does not show up on the my computer screen, it isn't recognized anywhere, but my 4 gig card of a different brand works just fine. I uninstalled and reinstalled the drivers for the SD card like i have seen so many recommend. I wasn't sure if it was a problem of the card or my system. any suggestions?
  • Memory
    62.2GB
Try the card in a friends computer first to see if it is the card or your driver.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
See what driver he has in device manager and download it from the manufacture to install on yours
    LENOVO 64734VM
    15 inch
I checked their driver and it wasn't very informative. They have windows 7 though, i might have been checking in the wrong place. under the catagory i checked for mine, it says the Rioch SD/MMC host controller, but she didn't have that, her's just said SD Card and didn't give any information except that it was a standard thing from microsoft, and under the catagory that I found the rioch driver, it only said on hers, "Intel(R) 5 series 6 ports ATA AHCI Controller" I don't know if that's the same thing, or where exactly to look on hers, since it's a different operating system.
  • Memory
    62.2GB
Try updating your Flash Media Controller Driver, that did it for me.
    LENOVO 64734VM
    15 inch
If that is a SDHC card and your system is from prior of about Apr. 2007, it may not be supported by your hardware.
    Dell
    Q6600
    HP w2207h
It's not an SDHD card, just SD. The thing was, it used to work... and then for a while it was give or take and then it just stopped working. The card works in other people's computers, and my 4 gig card works on my computer, just this one card doesn't work.
  • Memory
    62.2GB
Make sure both of these drivers are up to date
For some reason the highlight on SD Card didn't show but that is the other
    LENOVO 64734VM
    15 inch
I don't even have a memory technology driver showing let alone the flashmedia controller. I've been searching all over for a link to download it but everything i've tried doesn't work. =/
  • Memory
    62.2GB
    LENOVO 64734VM
    15 inch
Could you post a snip of your Device Manager please
    LENOVO 64734VM
    15 inch
Looks like you have four SD card readers,why four?
    LENOVO 64734VM
    15 inch
I can only say I have one and no problems.
Set a restore point and then remove some and try after each is removed.
If it is not helpful you can run the system restore again to go back to how you are now.
System restore is located at start,all programs,accessories,system tools,system restore.
    LENOVO 64734VM
    15 inch
