Scroll wheel works everywhere except IE7 and office
abssorb
Vista 64. The mouse is an old Logitech UltraX optical, which both MS and Logitech sya uses built-in Vista drivers. The mouse is recognised as a HID compliant device, so I don;t have many advanced options in the control panel / mouse options.
The wheel works everywhere except IE7 and office. Now I presume the office part will get fixed if I can get the IE7 part to work.
Any ideas?
    Intel Core 2 Quad Q9550 2.83GHz 12M Cache S775 1333MHZ
    Gigabyte S775 Intel P45 DDR2 ATX - GA-EP45-DS5
    8Gb. 4x2Gb sticks - Corsair 800MHZ NON ECC CL5
    Sapphire 512Mb Radeon HD 4670 PCI-Express VGA Card "HD4670"
    on-board
    Samsung 22" flat + Generic 18" flat.
    Western Digital 150GB VelociRaptor 10,000RPM SATA 16MB x2
    Enermax Technology 385W 82+ ATX 84-88% Energy Efficent PSU
    Antec P182 Mid Tower.
    OCZ Vanquisher
    MS Digital Media 3000
    20Mb cable
sounds like you might have a bad mouse- my optical with vista drivers works (scroll) in IE and office (though sometimes you need to click the page). I recently had to replace my wireless mouse because the scroll stopped working properly ( there is like a gear in it that clicks- half the time it just spun "freely", and It would not catch to allow scroll function).
If you slowly roll the scroll bar, and it doesnt catch/click every 1/8" of an inch, then it is bad.
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
It's not hardware. As I said....
It also works perfectly in XP and Ubuntu on the same machine (Dual boot Ubuntu, and XP on vmware).
    on-board
    OCZ Vanquisher
    20Mb cable
What might be happening in your situation is that the mouse isn't "fully" supported under Vista x64. "Fully" meaning not all functions will work. The fact that it fully works under XP just says supports what I'm saying, and especially if XP was the 32-bit version.
Looking at Logitech's website, I wasn't able to find the mouse (UltraX Optical mouse), thus no driver updates.
I would suggest a new mouse, or...
You could "try" using the new Setpoint drivers, http://www.logitech.com/index.cfm/428/149&cl=us,en?osid=13 but there's no guarentee it'll work.
If it doesn't work, well...
Just trying to help.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
