Safely remove hardware issue
ghettogreta
A little bit ago, I had hooked up my camera's usb to transfer pictures to my computer. I also had downloaded the camera's software. Ever since then, my safely remove hardware icon keeps popping up - even when there is nothing to remove.
I have uninstalled the software program, thinking that there was some random bug in there that was making the SRH icon come up, but that didn't work. I have clicked on the icon when it comes up to see what exactly it's telling me I can remove, but nothing shows in the window. Occasionally, a "disk drive" will appear, but when I try to click on it to see properties or to stop the process, the window doesn't respond, and it essentially freezes that window, and when it unfreezes it, the "disk drive" will be gone and I can't stop the process.
Now, the icon is annoying, but that's not even the part that's bothering me. I can hide the icon. The problem is that whenever it pops up on the task bar, my AIM program freezes. I'm someone who uses that and needs that program and the freezing is, well, it's annoying!
If anyone has any help as to how to disable this notification completely, not just hide the icon, I'd appreciate it.
Thank you!
