Blackhawk7188
Lately I have been playing Sims 3 and when I minimize it to check my AIM or email and such it says that I am running low on memory and that I should close the program. I just hit cancel ignoring it. I have 4GB of RAM and use 3D CAD and have never had that happen...even playing BattleField 2142 on the max settings. Is this just because I minimized the game and it has to store my session in memory and with some much going on at the same time pushes the memory to the max? If I check it in the task manager it runs at almost 1GB of memory whe minimized. The game is rated for 2 GB of RAM recommended...is something else causing this? I also do not use a paging file(reduces hard drive thrashing)...can this be the culprit? The notebook never slows down either so it definitely has me confused.
Check my system specs for more info.
Thanks in advance.
Thanks in advance.
- HP Pavilion DV7-1129wm Entertainment PC
- AMD Turion X2 RM-72 Dual Core @ 2.1GHz
- 2 x 2 GB Hyundai DDR2 400 MHZ
- ATI Mobility Radeon HD 3200 @ 256 MB
- IDT High Definition Audio/SRS Premium Sound/Altec Lansing
- 17" Laptop Screen
- 1440 x 900 laptop, external 17 in LCD 1024 x 768
- WD Scorpio Blue 320 GB SATA 5400 RPM Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
- PSU
- 8 Cell Lithium Ion Battery
- Case
- Laptop with "light up" HP Logo on outside
- Cooling
- Insane air coming out of Targus dual fan cooler
- Microsoft Wireless Mobile Mouse 3000 / Touchpad
- Full Keyboard with numpad
- Comcast Cable 20 MBps
- Other Info
- Used Primarily for CAD design using SolidWorks 2010. Also I love to watch HD movies using the HDMI output(Netflix). Linked to my Xbox 360 for Windows Media Center 3 USB ports + USB/eSata HP Remote for Windows Media Center and Quickplay Internal Dual Layer DVD+/-RW External HP Lightscribe Dual Layer DVD+/-RW HP Webcam and Microphone
