running a 32 bit on a 64 bit pc
What do you mean "run a scan"? The operating system is 64 bit, and you can't simply change it, and if you want to do so, you should downgrade your OS from 64 bit to 32 bit with a clean windows 32 bit installation.
im having trouble with a virus and i need to run a piece of scan software via internet explore to get it sorted but the software is only meant for 32bit and fails to complete on 64 bit
this is the scan
Eset - ESET Online Scanner
it should work fine mate , is it because you are using the 64 bit version of internet explorer? if you run the 32 bit version it might work , im just guessing here my 64 bit machine is switched off i cant test right now
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
From the website:
Eset-FAQ said:
Does ESET Online Scanner work with 64-bit versions of Microsoft Windows?
Yes, ESET Online Scanner works with x64 (AMD64 and EMT64) versions of Microsoft Windows—it does not work with Itanium (IA64) versions of Microsoft Windows. The ESET Online Scanner is a 32-bit application, which means it must be run through in the 32-bit version of Internet Explorer, and as an Administrator (see Q7, above). To do so, right-click on the Internet Explorer (32-bit) icon in the Start Menu and select "Run as administrator" from the context menu.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
