Router help needed
ian986
I have a wireless router which is netgear i am sure it is 802 56mbps I know have a 10meg connection is that router fast enough to cope with that internet speed?
The reason I am thinking of hooking this back up is, I have a virgin media connection which goes direct in back to computer, so have not needed this router for last few years,but now I want to connect my blu ray player aswell( So all i need to do is split the signal) and also if I use the wireless I will be able to hook up my i phone too will this work?
Thanks
    Q6600
    Gigabyte GA-EG41 MF-US2H
    Ge force 8600GT
    Sharp 37 inch LCD TV
    APEVIA X-QPACK
    Fan glowes blue
    Logitec MX5500 keyboard and Mouse
    10M Virgin
Hello,
Yes that router will easily handle your connection speed. Also take into consideration that not all of the devices will be using the internet at the same time as well.
Also, the iPhone will work with that router as well because I do believe that iPhone's have Wifi.
Hope this helps.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
The router I had has telephone cable not cat 5 lead! I am about to order one of these onlineNetGear WPN824 can confirm this will work for what I want as I have Virgin media cable which goes into black box and cat5 cable comes out?
Thanks in advance
    Q6600
    Ge force 8600GT
    APEVIA X-QPACK
    Fan glowes blue
    10M Virgin
