Solved Right click menu on a drive open option is not default
saurabhmal
Hi..Ca anyone help me....When I right click a drive on my Vista..it shows explore as the default option and is highlighted than the open....I check for trojans and viru but none were found...can anyone plz help me to fix this...any help will be greatly appreciated!!!
Ok...So correct me if I am wrong.....By default in Vista x64 Explore is the default option when right clicked on any drive in MyComputer so i need no to worry about any virus and Trojans....anyways I scanned my PC many times with nod32 and Malwarebytes and found nothing!!!
Correct. Explore is the default to open the folder or drive in the same window. No need to worry about it. You can change it to where Open is the default if you like in the link above to have a drive or folder open in a separate window by default instead. :)
Ok I got it,I was worried because I had connected an external with the sality virus ion it..I think Nod32 was able to prevent it into entering in my PC....thanks a lot dude....:)
You're welcome. :)
