Hi
I decided to restore my Toshiba L300 laptop to out of box due to all sorts of blue screens, freezes and shut downs. I managed to delete everything on the hard drive using the recovery. When asked to insert recovery disks to restore software did so and it ejected the disk and asked for the next disk which I inserted. Again it ejected and asked for the next disk so I inserted the third disk and again the same. It keeps asking for the next disk. I am using Vista so thought maybe the recovery disks did not copy so tried to install Windows XP instead. It loaded but when it says it is about to start I get a blue stop error screen. It does not shutdown though. I have wiped the hard drive again. I have tried starting while pressing F8 it doesn't work. I have tried turning off computer, holding down 0 while turning it on again. It starts the restore but won't read the vista recovery disks. Not sure if the DVD is only reading intermittently. If I start the computer I get the Toshiba innovations screen then it goes black with BootManager Missing message, press Ctl ALT DEL to restore. If you do this it just comes back to the same screen. Not sure what to do. Any ideas much appreciated. Thanks
