restore funtion not working
harlza18
hey all,
i have tried to get my system restore to work and it comes up with a error when i want to create a point.
Reason: The shadow copy provider had a unexpected error while trying to process the specified option (0x8004230F)
any help would be good.. cherrs
    Microsoft
    Intel Core Duo 2
    EP43-DS3
    E4800 @ 3.00
    Nvidea Geforce GTS 450
    Realtack high def
    BenQ T22IW
    1280X1024
    Maxtor STM 3320820AS ATA device
    logitch wireless mouse
    logitech wireless keybord
    running off a USB internet dongle
Are you using any backup software or partition software other than microsoft on your system. (Not for the restore perpose that you are having problems with)?
Do you close down your computer or use sleep?
Do you use any encryption programs?
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
i did try backing up my music to a flash drive and it did'nt work and every now and then a box will come up saying backup has failed. no i am not useing any encryption programes. what i am trying to find is how to put system restore points back on. thats the code which i have posted erlier. i do put my computer to hibernation sometimes but starts back up and give me a BSoD sometimes.
    Microsoft
    Intel Core Duo 2
    EP43-DS3
    E4800 @ 3.00
    Realtack high def
    BenQ T22IW
    1280X1024
Try shutting down your computer fully (to a power off state), then turning back on.
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
ok i have it set to a removable drive E:\ i might have to change that. would a dvd disc help or how do i turn it off???
    Microsoft
    Intel Core Duo 2
    EP43-DS3
    E4800 @ 3.00
    Realtack high def
    BenQ T22IW
    1280X1024
