Restore from Backup Help
Right Thanks.
I dont have a restore dvd
can i make one?
Do i have the require stuff to make one up?backup .old etc
one thing that i do know is that i can burn dvds.
thanks for your patience and help
    Dell Inspiron 546
    2.8 GHZ
    640 GB
    2 MBS
unless is a restore dvd my os disc
    Dell Inspiron 546
    2.8 GHZ
    640 GB
    2 MBS
charlie
what ever the computer came with. if you have a vista dvd all the better. if it is from the computer mfr it is a restore disk, either will work
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
i have a purple disk titled "operating system" that came with my pc from dell.
window vista home premium 64bit sp1 reinstallation dvd
    Dell Inspiron 546
    2.8 GHZ
    640 GB
    2 MBS
charlie You are set
put that in the dvd player and boot. it will give you the option to restore my computer IF you have a backup to restore from. try it and let us know how it goes
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
so just checking before i do this, what is my backup?
my .old folder or my file backup on my external harddrive.
so just put the disk in and reboot then...
    Dell Inspiron 546
    2.8 GHZ
    640 GB
    2 MBS
this is different form the Microsoft help right?
    Dell Inspiron 546
    2.8 GHZ
    640 GB
    2 MBS
C
where did you store your backup? is that backup from this OS or from the OS the windows.old folder came from?
If the backup is from this OS and it is on a HD make sure the HD is avilable when booting fro the dvd. this should not kill the apps and data on your system now but is there anything that you cant live without if something goes bad?
If not;
put the dvd in the dvd player boot from it (not the OS) and click on the restore my computer.
let me know if you need help
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
i have only ever had windows vista the and .old is from vista(it was made when i reinstalled it) i am now running vista. all backups are form vista
    Dell Inspiron 546
    2.8 GHZ
    640 GB
    2 MBS
but the .old folder is not on the ex hd but in my cd drive only there, does that need to be on the external hd
    Dell Inspiron 546
    2.8 GHZ
    640 GB
    2 MBS
which vista is teh backup from? this one or the last one?
the windows.old is from the last one
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
not going to be much help unless they are from this one.
do you need stuff from this install, or do you just not want to have to re-install your apps?
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
no i dont care about the one i am useing now(it can go) it is only a day old and has nothing on it, i just want to restore the windows . old folder from the last one.
    Dell Inspiron 546
    2.8 GHZ
    640 GB
    2 MBS
this seems t be what i want, will give it go when i have the time to morrow
i have added rep to all those who helped
thanks especially to zigzag your help has been extremly valueable and i hope that you remain to help the worldwide vista comunity in the way you have helped me today.
thanks once again.
Charlie
    Dell Inspiron 546
    2.8 GHZ
    640 GB
    2 MBS
cahrlie thanks jsut let us know if you need help. Im usually floating around somewhere
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
