resolution problem
preeti
hi!
Recently i connected my laptop to a projector, while the laptop was on. the resolution has changed. any idea how to bring back the original resolution?
I use ubuntu as the second os, buts its resolution is unchanged.
Hello preeti,
Try right clicking on the desktop, go to Personalisation, then Display settings, there you will find the options to adjust your resolution.
Hope this helps, good luck and post your results.
    Self Build
    QX9650 (black box) 3.0GHz@3.9GHz
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
