When i go to usb mode with my PSP and after i click on "safely remove USB mass storage device" from the bottom right of the taskbar, my PSP doesn't disconnect.... is it a bug or something?
Ufokrazy,
It is because of some services are running on background and those services are not releasing the USB. Hence you can either try to restart the computer and try to remove the file or you can just plug out the device. There is no problem in it.
