Remote logon
Hello Douwana,
You can disable Remote assistance (click on link) to prevent anyone from being able to log on to your computer remotely.
Be sure to also select the Don't allow connections to this computer option at the same link above.
Do you use a wireless router?
If so, you should enable "MAC filtering" in your router's network filter options (if available) and only allow your computer's MAC address access to the router. This way no one can access your router wirelessly and be able to connect or access your computers via the network.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Brink: where do i find remote assistance settings?
stoneys-nuts: is actually getting into my pc
i will secure my wireless conection, thank you, i'l let you know what i resolved
You can click on the tutorial link that I posted above. It will help show you how to step by step. :)
When you get it fixed, you may want to scan with this free app.
Malwarebytes
It will check for, and eliminate, anything that might of been left on your system, in the way of spyware and the like.
Good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
