Remote desktop question
MrBiggz
Greetings!
Here's my problem. My monitor died after 6 years of service and I'd like access my PC from wifes PC. Problem is I don't think I turn remote desktop. Is there some way I can turn it on from my wifes PC?
I can authent to it like if I map a drive. My sys is vista 64 and the wifes is vista 32, both are ultimate if that makes any difference. It'd be nice to remote to it so I can run some programs!
Thanks for any help!
    Intel Core 2 Duo E6750 @ 2.66Ghz
    Abit IP35 Pro
    4Gb Patriot PC1600
    EVGA (Nvidia) GT 430 1GB
    On board
    Syncmaster 2494
You can't turn on Remote Desktop remotely - otherwise anyone could do it and that would be a major security issue. It must be done on the computer that wishes to grant remote desktop access. You can map network drives and such because you have a network connection and it was established before the problem, but you can't control the other PC - that's the whole point of Remote Desktop.
Here's how it is done on the PC which you want to allow remote desktop to work on it: Turn on Remote Desktop in Windows 7 or Vista - How-To Geek - but that doesn't solve your problem without a monitor (unless you somehow memorize the steps and do it blindly, but I don't think it's likely to work and you would have to make some choices without being sure if they were the correct ones (because it isn't entirely a keyboard process and while you could use the keyboard, you wouldn't know where in the option lists you were to select the right options) even if you tried this and there's a risk you could do something bad without realizing it since you couldn't see what you were doing - I suggest you don't even try this).
Why not just move your wife's monitor to your PC long enough to enable remote desktop and then move it back? If not your wife's (maybe she has a laptop), then try to borrow one from a friend or neighbor or co-worker (or even from the office if they'll allow it) for an hour or so just to get this done. Then you'll be fine.
I hope this helps (or at least explains and gives you some options).
Good luck!
    1920 x 1200 pixels
Thanks Lorien!
I had a feeling that you couldn't. Didn't know if there was back door if you can authent to the other PC.
I would just move her monitor there but there's on little problem. The video card on my pc only has HDMI output no VGA and her monitor only has VGA.
BAH! Figures!
Thanks tho for the effort to tap the reply out!
    Abit IP35 Pro
    4Gb Patriot PC1600
    On board
    Syncmaster 2494
Check out neighbors, friends, co-workers, the workplace (if they'll allow it), relatives or ANYONE with a monitor (maybe even an old one they no longer use) that will work with your video card to see if you can find one you can borrow long enough to do this.
I don't know both of your computers, but can you switch her video card as well as her monitor to your computer (you may need drivers but you can get them in advance and have them ready if needed)? If it's a separate card of a similar type that will fit in the motherboard slot, then this may work. If the card is built into the motherboard then forget it as it cannot be removed by anyone but a true professional. Just another option to consider.
The only other suggestion (not really a suggestion - more like an alternative that I don't really care for very much because I don't think it's a good thing to do but present it because it will probably work) I have is to buy a new monitor that works with your system. Make the required changes and confirm it works. Then you can decide whether you like the monitor enough to keep it or if it doesn't suit you (and maybe we sort of knew that from the start) return it for a full refund (confirm that's possible before you purchase it and how much time you have to do so). Save all the packing material and documentation and everything that came with it so if it is returned you won't be charged for anything being missing. It's a lot of hassle and maybe not exactly a nice thing to do if intentionally returning it is planned from the start, but it should resolve the problem (by which I mean, allow you to do your workaround).
Though to be honest, how you can live this way using her computer with remote desktop instead of actaully just replacing the monitor is beyond me. My wife and I would be at each other's throats to use what would really now be the one computer and there may be some things that cannot be done even with remote desktop (I don't have a list, but I've done it before with GoToMyPC and similar programs (never with only Vista's remote desktop) and in certains cases I needed the user to do some action that I wasn't allowed to do - and I imagine the same holds true here though I'm not completely certain - but I suspect you'll discover any such limitations if they exist in time. One likely limitation is the ability to make network changes - either by being denied access or because if you do you may not be able to connect at all (you may alter network access to prevent it from being possible at all) - remote desktop or mapped drives or anything - and then you'll be back in the same boat you started in only worse because you won't even have access to the mapped drives). While I cannot recommend this option unless you go into it actually considering that you will keep the monitor (in which case you don't really need remote desktop but you can enable it if you want just in case). Although it is a slight security risk to enable this feature, if your security is otherwise tight (you use an administrator account only when needed and a standard account most of the time, the Windows Firewall is enabled and exceptions are limited to only those you actually use, you have strong passwords on all user accounts, the guest account is disabled, and so forth) then it is a minor risk. I personally keep it disabled as I am a bit security-conscious but that decision is up to you. If it had been enabled, you wouldn't have needed to post here with this issue.
I hope this helps.
Good luck!
    1920 x 1200 pixels
