Registry Repair Pro is rogue software?
albar33
I downloaded this software today & now I cannot delete it using install/delete, delete within the software, & my system restore does not work. Any recommendations for Vista 64 bit would be appreciated.
    Dell Studio Slim 540s
    Intel core2 Quad 8200
    6110 Meg
Try the manual way to uninstall.
Remove RepairRegistryPro files and dll’s
RepairRegistryPro.lnk
pcsd.dll
Repair Registry Pro.db
Repair Registry Pro.exe
log.dat
settings.dat
[RANDOM FILE NAME].tmp
program.info
Uninstall.exe
Start Repair Registry Pro.lnk
Uninstall Repair Registry Pro.lnk
Unregister RepairRegistryPro registry values:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\
Uninstall\RepairRegistryPro
HKEY_LOCAL_MACHINE\SOFTWARE\Repair Registry Pro
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{82297D11-31C1-40B1-960A-BDF40B3B365F}
HKEY_CURRENT_USERS\Software\Repair Registry Pro
HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\pcsd
HKEY_CLASSES_ROOT\CLSID\{82297D11-31C1-40B1-960A-BDF40B3B365F}
Uninstall\Repair Registry Pro
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Sorry, it didn't work. It had also had immobilized my system restore as well as "locking " the delete function when attempting to delete the files. I finally deleted it by repairing system restore & restoring to a previous time. Thanks for your efforts!!:geek::geek::geek:
    6110 Meg
USE REVO UNINSTALL. TURN OF WINDOWS RESTORE IN THE PROGRAM UNDER SETTINGS..... FIND THE PROGRAM UNDER THE LIST. DO A COMPLETE UNINSTALL, IF IT FAILS, CLICK NEXT, IT WILL LOOK FOR FILES LEFT BEHIND DELETE THEM ALL,
If it asks to restart the computer do so, after the files are all deleted. And now it should be deleted :)
