Registry Problem
MatthewFireston
So I can't set any printer (Local or Network) as a default printer. After some time debugging I have stumbled upon a bunch of missing registry's. It seems that under HKEY_CURRENT_USER\Software\Microsoft\Windows+NT\CurrentVersion\Devices there are no printers listed and as a result I can't set a default. Under HKEY_CURRENT_USER\Printers\ they are all listed. I can print under MS Word but not Excel, Power Point, Adobe etc. (programs that require a default printer).
Some more information about my computer:
Windows Vista Home Premium 32bit
UAC is Disabled (I tried turning it back on to solve the problem and that didn't work)
I have a Xerox Work Center 7345 connect through a TCP/IP port with IP 10.1.1.40
I have re-installed the printer drivers 2 times. Didn't fix the issue.
