Solved Recycle Bin problem
CRPishere
Hi all,
I have 4 files present in my recycle bin ending with the .dat extension. I cannot delete, restore or do anything with these files without causing a hang. Any other file present there causes no problems. Any attempt to empty the bin causes a hang however I can delete individual files no problem except for these 4 files. Any suggestions?
CRPishere
Hey Brink...... thanks for the reply. I don't know what happened but the problem cured itself. After several tries, reboots etc nothing happened. I decided to have another go and when I opened recycle bin the files were gone. Go figure.
CRPishere
I'm happy to hear that it sorted itself out for you. :)
