You should upgrade or use an
alternative browser .
Solved Recycle bin problem!
Hi, I have a problem with my recycle bin. When I delete a file I am not seeing it in the recycle bin but it is there and I can restore it. The recycle also shows full on the desktop.
intel core 2 quad
Acer FG965M
2 gb
EVGA geforce 640mb 8800 GTS
500 GB
Resistance is Futile
If you open the recycle bin and press <F5> to refresh, does the bin listing show correctly?
This was a common problem that I encountered several times. Since installing SP1 I have not had this problem.
Do you have SP1 installed?
AMD Phenom 9600 Quad
ASUS MB-M3A32-MVP Deluxe/WiFi
2 x A-Data 2GB DDR2-800
ASUS ATI Radeon HD 2400PRO
SAHARA 21"
1600x1200
2 x 80GB Seagate (I)
2 x 120GB Seagate (I/S)
2 x 200GB Seagate (I/S)
2 x 250GB Seagate (I/S)
800W
Thermaltake Tai-Chi
Tai-Chi Water Cooler
Genius
384kbps
I pressed F5 in the bin and I still don't see anything. I have sp1 as well.
intel core 2 quad
Acer FG965M
2 gb
500 GB
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
If I understand you correctly, the bin works correctly, but you cannot see the deleted file. Try going to change icon and reset it to one that correctly shows the status at the time of change, ie full or empty.
I tried method 1 and it didn't work. Then I went on to method 2 and I discovered that I am not seeing the $RECYCLE.BIN folder when I show hidden files.
intel core 2 quad
Acer FG965M
2 gb
500 GB
Memphis,
Did you also uncheck Hide protected operating system files ?
If so, see if refreshing the window or desktop does not show it. If not, then restart the computer to have that file rebuild itself automatically.
Operating System
Operating System
Sorry I Didn't do that. I am seeing the folder now thanks.
intel core 2 quad
Acer FG965M
2 gb
500 GB
No problem Memphis. Is your Recycle Bin working properly now?
Operating System
Operating System
My recycle bin is still not working properly and the situation has become worse. When I delete a file I am not seeing it in the recycle bin and I am not seeing it showing full on the desktop. I can only undo delete
intel core 2 quad
Acer FG965M
2 gb
500 GB
Memphis,
Since that did not help, you might consider a
System Restore using a restore point dated before you had this Recycle Bin problem to see if it can fix it for you.
Operating System
Operating System
shweew...Finally I did the system restore and my Recycle bin is back to normal. Thanks for the assistance Brink, I really appreciate it.
intel core 2 quad
Acer FG965M
2 gb
500 GB
You're welcome Memphis. I'm happy to hear it is working properly now.
Operating System
Operating System
