MR0808
I currently have an Asus M50SA laptop running Windows Vista Ultimate 32bit. Recently my hard drive was failing and had to get it repaired. So I used the Windows Back up utility and backed up the entire hard drive to an external 3.5 inch usb hard drive.
I then sent my laptop off to get repaired and they took out the hard drive and put a new one in and re-installed Vista for me. However, when I went to run the recovery program from the install disk, it kept coming up with the error that it could not find any backups. Using the command prompt though, I could connect to my USB drive and see the image.
What do I need to do to get the recovery software to see the VHD file on the USB drive?
