ParadigmRG
Hello,
I just reloaded my PC with win7 x64. After hunting about i installed the new win7 realtek drivers and Wireless LAN Utility. I was able get the soft AP up and running. I have to wireless laptops (one XP and one Win7). The Win7 laptop can connect to the soft AP (usually). However, the laptop running win XP can not. After some researching, i came to the conclusion that the laptop wireless atheros card can not use WPA2 security authentication.
The Soft AP Wireless Utility will not let me change the Network Authentication - it is grayed out and set to only use WPA2 ???
Does anyone know how i can get the security setting to let me change it to other settings like WPA or Open???
Any help will be appreciated. Otherwise guess i be buying a new stand alone router.
FYI
Win 7 x64
Asus P5W DH Deluxe
Realtek RT8187 Wireless
Thanks,
ParadigmRG
FYI
Win 7 x64
Asus P5W DH Deluxe
Thanks,
ParadigmRG
