First post here so greetings to you all
I have got a problem with Firefox, Internet explorer and Windows live messenger. They were all working fine untill a few days ago. When I try to start my browsers the come up with: Cannot display this page. Messenger just doesn't connect at all. Windows updater cannot connect to the server and my virsus software cannot connect either. This problem came completely out of the blue and happened randomly when I was surfing the internet.
The weird thing is that Steam is still running and is still connected to the internet, so I can play online
games and access my friends list but NOT the online steam community. This implies that the connection to the internet is still there, but browsing of any descption will not work.
I have tried Repairing the network adapter, restoring to a system restore point a week before the problem started to happen, putting my PC in a DMZ plus zone in my router options, starting up in safe mode to see if a start up program is casing the problem. However none of these worked.
I have done virus scans with NOD32 and a few spyware searches and nothing came up.
I typed into the Command Promt IPCONFIG/ALL and the following came up:
C:\Windows\system32>ipconfig/all
Windows
IP Configuration
Host Name . . . . . . . . . . . . : ****
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : gateway.2wire.net
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : gateway.2wire.net
Description . . . . . . . . . . . : Realtek RTL8168B/8111B Family PCI-E GBE N
IC
Physical Address. . . . . . . . . : 00-1F-D0-85-26-**
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : **.159.107.185(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.252
Lease Obtained. . . . . . . . . . : 08 March 2009 11:26:55
Lease Expires . . . . . . . . . . : 08 March 2009 12:01:55
Default Gateway . . . . . . . . . : **.159.107.186
DHCP Server . . . . . . . . . . . : 192.***.1.254
DNS Servers . . . . . . . . . . . : 192.***.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-**
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : isatap.gateway.2wire.net
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : 6TO4 Adapter
IPv6 Address. . . . . . . . . . . : 2002:519f:6bb9::519f:****(Preferred)
DNS Servers
NetBIOS over Tcpip. . . . . . . . : Disabled
Some numbers have been masked.
Im running Windows Vista Ultimate 64 bit edition.
Any help would be much appricated as I don't have a clue what to do!
Tinlee
Windows
IC
DNS Servers
Tinlee
