RAM Speed question?
unexpectedjoe
Hello,
I installed the following ram on my PC
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
I have also installed the NVIDIA system monitor.
My question:
Why does my computer recognize the RAM at 800mhz (this shows on boot up and in the Nvidia monotor) when my motherboard supports 1066 and the ram is also 1066.
Any help would be appreciated.
I have a p7n diamond 780i motherboard from MSI.
Thanks
Hello,
My question:
Thanks
the ram divider is probably set to a ratio of 1-1 in the BIOS which will lower your ram speed to match your systems FSB
download this app & check the memory tab ..this should give you your current ratio...
CPUZ
if it is in fact 1-1 its an easy fix ...
enter the BIOS not sure about your boards actual layout but in advanced options there should be an option to alter ''ram frequency'' or ''divider'' set this to either 1066mhz or the nearest ratio to that value & reboot
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
Thanks for the info. I downloaded that program and I attached a screenshot of the memory tab that you said to look at.
I'm not sure what the timing is... Does it look like I need to change a setting in my BIOS?
I also verified that my motherboad supports dr2 1066.
post me your cpu tab also ...so i can check it against the bus speed....
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
ok ....go into the BIOS & change to a higher ratio or frequency whatever the case may be on your board....you should not need to up the VDIMM as the ram sticks are currently under clocked
but i would aim for 1000mhz 900mhz OCZ ram is renowned for not reaching rated speeds
or OC that little gem of a chip to 500FSB & that will give you 1000mhz @ a 1-1 ratio
if you cannot get them past 1000mhz (which is a probability) keep them @ 800mhz & tighten the timings to 4-4-4-12 or whatever those ICs will sit stable at
this will give you very close to or the same perfomance you would get from the higher frequencies & looser timings
jump into the BIOS & let me know what you see...:)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
I spoke with OCZ about this same issue (I have the 2 x 2 GB HPC ReaperX PC8500 RAM) and they said the reason is because there is not a JEDEC standard for PC8500 so the motherboard will recognize only the JEDEC settings prescribed onto the RAM - which is PC6400.
You'll need to manually adjust your BIOS settings to match the settings stated by OCZ.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Unless you plan on overclocking, anything over DDR2-800 is a waste. The reason to get DDR2-1000 or 1066 is to give you more overclocking headroom, that's it. If you were to set your RAM to 1066, unless you also overclocked your cpu, you would not see any performance gains. In fact, since you'd have to relax your timings, you'd most likely see a small dip in performance... not much granted, but still a small dip.
Don't just OC willy-nilly. Read this: http://forums.overclockersclub.com/index.php?showtopic=71656
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
OK,
So I went into bios, then "cell Menu" then I changed "system clock mode" to "manual". There, I was able to change the "dram clock to 1066" I saved the settings and exited.
I saw that there was "dram timing mode" that was on "auto" I left it there.
I attached a few screen shots of that CPUZ program.
The last post said that since I sped up the memory clock the timing may automaticaly change as well which will actually slow the memory? So, in some cases slower mhz can be faster with the correct timing?
With the changes I made the Nvidia system monitor shows the memor clock at 1065mhz.
Thanks
OK,
Thanks
THERE YA GO.....
533mhz x2 = 1066mhz :D
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
... The last post said that since I sped up the memory clock the timing may automaticaly change as well which will actually slow the memory? So, in some cases slower mhz can be faster with the correct timing?
At DDR2-800 your timings were 5-5-5-15-24 2T. At DDR2-1066 your timings are 5-7-7-20-32 2T. Clearly, at DDR2-1066 your timings are looser. I would imagine that with the proper voltage you should be able to run 1066 at 5-5-5-15, but you'd have to test that out?
How does what you just did affect performance? You may noticed slower system performance now that timings are looser. Simply increasing the memory clock doesn't do anything. Also, leaving the memory timings on auto doesn't take advantage of the increased memory speed. Not that there was any great advantage to what you did to begin with since you also didn't OC the cpu, but I digress.
If you want to improve performance, read the OC guide I linked. OC the cpu and run 1066... at 5-5-5-15. Then you'll see things speed up.
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
i have to agree with fumz ....
even though im obligated to answer your query's to raise the ram frequency i believe tighter timings give better performance increase
you will see NO increase in performance going from 800 to 1066mhz
but you would see a difference going from 800mhz @ 5-5-5-15
to 800mhz @ 4-4-4-12
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
