Racing a K-car and Escort
doclobster
This isn't the greatest race, I know, but I have an acer aspire 2.8 ghz quadcore, with 4 gb ram. I'm running Vista home premium, 64 bit. It comes with an onboard ATI Radeon HD 3200 graphics card.
I also have a ATI Radeon X1650 pro left over from my previous computer.
Does it make any sense to install this low budget card - with its dedicated RAM (512 MB if I remember correctly) or should I just stick with the on board video card. I believe it dedicates 128 MB of the RAM from the mainboard and borrows more when necessary.
I'm not a serious gamer - but if the 1650 will make my computer run better for other applications I'm interested in changing it.
Thanks
  • Memory
    4gb
    ati radeon hd 3200
    Mag 22"
    cable
trial and error is all i can say :)
just see if it works any better, if not just take it out! LOL
-Braydon
    Waayer Customs
    Intel Celeron Dual core @ 2.0Ghz
    ASUS P5kpl-1600
    2X Kingston 1600 1GB DDR2
    Zotac 9800GT 512MB
    VIA onboard HD audio
    Philips 107S6 CRT
    1280 X 1024
    Seagate 250GB SATA Maxtor Basics 250GB EXT USB Drive
    Ultrix 550WATT
    Atrix 9001
    1 normal Fans 1 QUAD Colour
    Logitech V220 Wireless
    DSE multimedia/Internet Keyboard
    8.22MB/s DOWN 0.1MB/s UP Bigpond ADSL2+
    Asus EeePc 701sd, 8GB SSD, 2GB RAM, XP pro
Well, I did contemplate it - but I have to admit that I'm new to this Vista 64 bit business and I've hated the driver experience to this point. I probably will try just that. I suspect I won't notice much difference at all.
thanks
  • Memory
    4gb
    ati radeon hd 3200
    Mag 22"
    cable
install the card mate........;)
the X1650 PRO is far better than an onboard solution, here you can see the two performance wise, both these results were done with comparable CPUs
HD3200..
X1650 PRO..
thumb.php
if nothing else it will alleviate load from the mobo.... this is what the card requires.......350-Watt power supply or greater (assumes fully loaded system)
the system should feel smoother....IMO
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
That's what I was thinking - just not sure.
thank-you, I'll give it a whirl.
  • Memory
    4gb
    ati radeon hd 3200
    Mag 22"
    cable
