AutocadUser
Just obtained new Owner Version of Ultimate (32 and 64). It says 3 different installs allowed.
I wish to use it on 2 hard drives in same computer, one 64 bit, one 32 bit for testing our AutoCAD Addin Sofware. Will likely re-do the current 64 install (done by this owned package) to 32 (as 64 is on the new & larger drive, a mistake on my part), then install 64 again, but on smaller hard drive.
This has me concerned as to how MS views the number of installs (limitted number), especially as within the same computer, same basic configuration.
1. Will I soon run out of my allowed installs, or will they be considered as just one as is on same machine??
2. Does MS have any problem with 2 installs active on one computer (separate hard drives)?
