Questions About my network
jervin
yesterday i buy a wireless broadband router - 4 ports
and i encounter some change.. i dont know if it is a problem with the settings or it is normal...
questions:
1. My desktop computer is connected to the router through Lan. when i start the computer. my comp identifies the network for 2 mins.. it is normal? or i need to change settings or the router?
2. i cannot connect to my other PC that is also connected in Lan.. see ScreenSHoot below
Are the computers connected by Ethernet cable or via wireless ?
Have you checked to make sure your security, firewall, anti virus, is allowing access ?
I've just noticed that you are posting in the Vista forum but using Windows 7, perhaps you'd be better posting in Sevenforum where the experts with that system can be found.
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
