I am trying to figure out what version i have, I purchased THIS version off NewEgg thinking it was the full version... once delivered i soon figured it was the upgrade due to limited packaging... then i installed it... the UPGRADE option was actually not an OPTION... so i figured with the clean install it would wipe my HD first then install..
but after the install, there was an OLDWINDOWS folder with all my previous crap... so am guessing it didn't do a fresh install-- am so used to XP were you actually saw the reformat... which i always do when re installing an OS....
so how are you suppose to know what version you have - full or upgrade -- when the packaging doesn't tell you??
or does the clean install reformat and just save your old files??
sorry for being a Vista Noob! was at bestbuy looking at the different versions of vista all said UPGRADE on the box along with the Ultimate version that i guess contains both the 32 and 64 bit-- and says in system specs to run a clean install...
so confused---
thanks...
so confused---
thanks...
- Intel 6850 3.0gzh
- EVGA 680i
- 8 gigs OCZ PC8500
- EVGA 8800GTX
- WD Raptor 150gig 10k rpm
