Quattro Pro & Vista
oldspirit
I am using Vista 64bit Home Premium on my HP Pavilion notebook. Prior to my using this laptop I was using XP on another machine. During the time using XP I used Quattro Pro 12 (qpw) ending, as my spreadsheet program.
Transferring files from the XP to Vista was the worst experience to date with Windows products. After transferring the files, I attempted to install Corel 12 on my laptop without any success. At the time I spent time on the net seeking solutions, it seems other persons where having the same problem. I found out that Corel was not providing a solution (Dec 08) and then I did a stupid thing. Ash can'd the corel program and decided to use open office.
Now I have a need to access my qpw files. Are there any worksheet programs out there which will open my .qpw files? Do you know if any of corel worksheet products will work on VistaX64 Home premium?
Any help will be greatly appreciated. Never, never again will I pitch software programs.
thank you:D
