Solved pz freezing ingame, needs hard reboot
Perentie
hey guys, im sure theres been a few others with this problem but i cant find a solution anywhere so ill try here, pc runs fine untill i load a game up pretty much WOW it effects the most, could be after 5 mins of loadin the game up i can get a freeze unable to ctl/alt/del etc only way to get out of the freeze is by a hard reboot, but sometimes it can go a day or 2 without a lock up.
ive had this exact same problem since i bought this pc around 9 months ago, originally it had a 8800 gfx what i blamed for the random freezes ingame so i switched to an ATI 3870HD and it seemed fine for a while but the problem started to reacure again about 2 months ago, only solvable by a hard reboot, i also tried everything to fix this ie: new drivers, new hardware formatting partioning the drives etc and still the problem persists even after buying 4 gig of new corsair too.
is there a way i can check the heat sync on the mobo? to see if its overheating as before i replaced the 8800 nvidia the shop i bought it from said thats what was causing the problem
system specs are
intel core duo e6750 2.66GH.z 2.66GH.z
3327 memory
650w psu
3870hd gfx
300 gig hd
any insight would be mucho appriciated thx
system specs are
3327 memory
650w psu
3870hd gfx
300 gig hd
You can check the temps with this piece of software http://www.alcpu.com/CoreTemp/http://www.cpuid.com/cpuz.php
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
thx for posting, ill try that now cheers
both cores are running at 43 degrees, is that about right?
forgot to mention my bro bought the same pc me as me 2 days after, and he suffered the same freezes also
I am assuming that both your video and audio drivers are up to date? I am not talking about the drivers that came from your CD but the latest drivers from each manufacturer?
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
i updated the gfx drivers yeah, i have no 3rd party sound card atm tho, the audigy 4 i had didnt seem compatible with vista, i aint the brightest tho when it comes to pcs so dare i ask how i update the sound drivers? my motherboard is a gigabyte S-series N650SLI-DS4 thx in advance
OK, here's the Bios update if you feel comfortable flashing your bios. Latest Version is F8F. Reboot your PC and check to see what version you are running at the moment as you may not have to update.
GIGABYTE - Support&Download - Motherboard - BIOS - GA-N650SLI-DS4 (rev. 1.0)
Here you will find drivers for your chipset, audio and Sata... download those that you need. I was going to assume you are in the US but I rather you choose where to download from ;)
GIGABYTE - Support&Download - Motherboard - Driver - GA-N650SLI-DS4 (rev. 1.0)
    EVGA GTX260
    1680 x 1050
    Logitech G7
    Logitech G15
