PSE with Vista 64 bit HELP PLEASE!!
gilchristtd
I am new to this forum and stumbled across it while searching for a solution to my problem. I have read a lot of conflicting posts so I'm not really sure what to do. I tried to install PSE 7 (2X) on my new HP desktop (6 GB with Vista Home Premium 64 bit). It seemed to install fine, however won't launch. When I try to open it from the desktop icon or off of the c drive - program file i get a messge that reads "MISSING SHORTCUT - Windows is searching for photoshop elements 7.0 exe to locate the file yourself click browse" I would really appreciate any help anyone can offer. I only have 2 weks to decide if I want to keep this computer. PSE is the main program that I run on it. Be gentle with me - I am not completely computer illiterate however some of the lingo is sometimes a little puzzling to me.
Thanks in Advance
Tracy
GC
right click the app and click open file location. It will and then see if the app is there and can be launched
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Thanks for your quick response. I tried that and got the same message. I can open the c drive and go into adobe folder and all the contents are there. however i can't see the exe file - which to my understanding is what i need. Any other thots? I have loaded this succesfully onto a previous laptop and have had no problems with it.
Look in C:\Program Files(x86) for it or C:\Program Files.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Where did you install it?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
